Granddaughters car washer reservoir keeps losing fluid .One suggestion is to remove front bumper to checkit and another is just the inner guard plastic cover.Has any one done this.Motor seems ok .Any advice appreciated.
Aug 26, 2:37am
If you can peel the guard splash shield back far enough to find what the issue is, whether the pump seal is leaking, hose leaking, cracked reservoir, whatever it is, it may save you having to haul off the bumper until you can order in a new part or decide otherwise how to fix it.
Aug 26, 2:52am
easiest way IMO is to lift the front of the car up safely . Wheel off. Unclip the poppers and screws and whip the front inner guard out. It should fold back out of the way fairly easily That should give you a clear view of the pump and the bottoms of the hose.
gazzat22,
Aug 26, 3:15am
Thanks you two.You,re legends ,and I mean that sincerely.
bigfatmat1,
Dec 2, 3:43am
10 mins max to pull.front bumper off if you need to replace it.
