OBD2 fuel economy guage on CE Lancer Wagon
intrade, Jan 26, 10:17pm
2000 mitsubishi i doubt it will give you any readings a lot of early 2k mitsubishi still used obd1 and only added the obd2 port because the knotheads in california made it mandetory with a Y cable for diagnostic like in my cable set from launch Diagun for mitsubishi
intrade, Jan 26, 10:20pm
if you want to save money then do your services on car new air-cleaner and check tyre pressure every 14 day.
tygertung, Jan 27, 1:43am
Probably only drive the car every 14 days. We don't typically use it for around town, I mean why would you, if you have the use of your legs.
We usually only use it for long distance travel or carting building supplies.
intrade, Jan 27, 1:48am
ummm your not going to save fuel carting building supplys.
ronaldo8, Jan 27, 2:56am
step one: refill tank
step two: write down litres and k's in notebook
drive
step three: go to step one.
eg
https://play.google.com/store/apps/details?id=com.mycarservice.mycarservice
tygertung, Jan 27, 3:51am
I don't think you understand. I wish to ascertain a live readout of fuel consumption to allow driving in the most economical fashion.
Of course I can work it out when refilling, but that doesn't really help much. I might be going up a hill and wish to find out whether the engine is more economical in second or third gear for example.
ronaldo8, Jan 27, 5:06am
Now I understand that you failed to explain what it was you want to do.
There was no mention of live readouts.
tygertung, Jan 27, 5:15am
Sorry, perhaps I was unclear. When we get rental cars, I find it of great benefit when it has the live readout as I am able to conserve fuel = more beers.
sw20, Jan 27, 9:34am
Just drive at 30km/h in town. 70km/h open road. You will save loads of fuel.
tygertung, Jan 27, 6:24pm
Arbritrary figures like that are not going to be so good as it might actually be better to go 80, that's what I want to know.
I might order one of these, they are $130 AUD but the exchange rate is good, so only $140 NZD.
http://glengineer.com.au/mpguino.htm
toyboy3, Jan 27, 8:42pm
If you want economy fit a manifold vacuum gauge and drive with the highest readings
bill-robinson, Jan 27, 9:05pm
i usually reset trip meter when i fill up.i have checked the fuel consumption with the onboard reading and guess what they are within 0.1km of each other
tygertung, Jan 27, 9:29pm
Rad as, I wish my car had an onboard reading as well, but it doesn't and I want to fit up an onboard reading meter.
bill-robinson, Jan 27, 11:38pm
iu was trying to show you that there is very little difference between what you have and more confused electronics. if you cannot do that there is no hope.
supernova2, Jan 27, 11:43pm
I agree. Several cars had those fitted back in the 80's or there abouts.
tygertung, Jan 27, 11:49pm
You seem to miss the point. I want to know if driving in second gear up the hill, or third gear is using less fuel. I want to know if driving at 90 or 100 kmh is using less fuel.
It is no use working out how much fuel I am using over an entire tank of fuel.
bill-robinson, Jan 28, 12:52am
to many variables to bother with. drive it like the truckies do, get it up to speed and keep it there using min throttle, avoid hills and drive on the flat whenever possible.
saxman99, Jan 28, 1:28am
You could do what I did - buy an old V12 and never worry about fuel economy ever again. ?
Warning: This option may result in GrinningLikeAnIdiot syndrome.
tygertung, Jan 28, 1:51am
That is your opinion, but not what I was asking for.
bill-robinson, Jan 28, 2:51am
let us know when you finish your on the fly ecometer and what the results and costs are please
ronaldo8, Sep 22, 3:06am
The vacuum gauge is definitely the best way to educate yourself how to drive economically. The trip meter in my car does what you want, its not that usefull as it just underlines being smooth. Drive smoothly, don't accelerate hard, maintain as constant a speed as possible with the motor easy breathing air not gulping it. Your ears are as good an indicator as anything.
