Sump Plug Mitsi EX Lancer 19mm Stuck!
mike107, Nov 9, 6:36pm
Slightly rounded! 19mm socket or ring spanner slip off, don't want to round it anymore. Any Ideas!
therafter1, Nov 9, 6:36pm
Pipe wrench.
therafter1, Nov 9, 6:37pm
Failing that ,,, cold chisel lol
mike107, Nov 9, 6:38pm
I tried vice grips, might take to my Mechanic Tomorrow.
bevharris1938, Nov 9, 6:40pm
Hacksaw a slot in it and use a bit flat blade screwdriver.
mugenb20b, Nov 9, 7:25pm
Yeah, right! Tui!
ralphdog1, Nov 9, 7:27pm
6 sided 19mm socket!
mugenb20b, Nov 9, 7:29pm
Err.dude, Mitsis have a 17mm sump plug.
savanna71, Nov 9, 7:34pm
except for the mitsis that have 13mm, 19mm,or 24mm
mugenb20b, Nov 9, 7:37pm
I've never seen a Lancer with a 13mm, 19mm or 24mm sump plug. Unless OP is talking about a pre 1985 model.
savanna71, Nov 9, 7:38pm
you said mitsi, not lancer. However you will see op said ex lancer
mike107, Nov 9, 8:03pm
YES 19mm 6 side 4G32 1982 EX Lancer RWD 1600cc.
mike107, Nov 9, 8:11pm
I can lap valves in on a 73 GTO colt , change the clutch on a 88 mirage but I gave up at 9pm on a Lancer sump plug! My mechanic can get it on a lift tomorrow for more leaver angle with some vice grips!
mike107, Nov 9, 8:17pm
It did get me! I am slacked off with myself! I have a replacement plug off an old 4G52 and a New alloy washerso it will not happen again. Thanks Guys!
ceebee2, Nov 10, 6:19am
I would have simply used a coal chisel and beat the cr**p out of it, replaced with new plug and washer.
mike107, Nov 10, 6:08pm
****FIXED IT !****** Thanks for all the ideas. Friend came over tonight with a BIG Stilson and munched it off. Got NEW 19mm Mitsi Sump plug and alloy washer! All good!
neville48, Nov 10, 6:29pm
TIP; Get yur friend to nip it up with the big stilsons too so it doesn't leak.tee hee.
bubbles244, Feb 16, 2:15pm
nz new ones do.
