There is about 2mm play in rear universal joint on end of drive shaft that bolts to diff. Would this cause car vibration at 70 to 90 km/Hr! Thanks.
mike107,
Nov 11, 6:38am
Vibration is in the seats like a back massage.
falcon15,
Nov 11, 10:18am
there shouldnt be any play in the driveshaft universals. that would cause vibrations
therafter1,
Nov 11, 10:20am
99% chance that the U/J is the source of the vibration.
therafter1,
Nov 11, 10:44am
Play in a U/J is a WOF fail anyway, so you will kill two birds with one stone.
mike107,
Nov 11, 3:38pm
Taken Drive shaft off, play in U/J by diff, will change it out. Thanks Chaps. The little EX has been a Grannie car for 25 years, sorting some things out on it!
timaru2009,
Nov 12, 7:53pm
Also Check for missing weights on Drive shaft, some are balanced like a wheel. This can cause further things to fail.
mike107,
Nov 13, 3:34pm
Pressed out old u/j today and fitted NEW U/J, all fixed, weights were still on drive shaft, Thanks.
timaru2009,
Feb 27, 8:46am
Glad to see you have it sorted :-)
