What petrol to buy
campmother2002, May 26, 8:25am
I have just bought a 1985 2lt mitsubishi l200 sport ute,unsure which octane rating to use
jasongroves, May 26, 8:39am
Minimum recommended is 91.
grangies, May 26, 8:42am
Both fuels are unleaded so you have no choice, regarding lead fuels.
So what will it matter!
It's more of a performance issue.
jasongroves, May 26, 8:43am
Who mentioned anything about lead! There is more than 2 different types/octane/blend of fuel available too;)
mybaby, May 26, 8:43am
Are you seeing things we cant!
skyline_guy_r34, May 26, 9:23am
Whats the compression ratio!
campmother2002, May 26, 10:35am
Don't know, have got no information at all!
henderson_guy, May 26, 10:41am
I have a '97, found it runs best on 95.
cp2011, May 26, 11:16pm
yes ive found they run best on the highter octane stuff
elvis58, May 26, 11:55pm
The old g63b in those run fine on 91. They have a bad habit of having stuffed vac advance units on the distributor if you are having problems.I don't believe you will notice any difference running it on a higher octane fuel.
johnf_456, May 26, 11:57pm
91 will be fine
antwerp87, May 27, 12:01am
E10 Is great if your in an area that can get it. As long as you maintain it and run 95 in it once every 6 months or so it will go like a charm. Was using it the entire time I was in Brisbane. Saved so much money and really didnt cause that much wear and tear either
Share this thread
Buy me a coffee :)Buy me a coffee :)
