Leaking petrol tank
craig70, Feb 4, 4:39pm
Just would like to know best way to fix this without taking it out and getting it welded. Was going to try some j-b stik on it .Leak is a pin hole on bottom of tank.
morrisman1, Feb 4, 4:42pm
knead it steel, first I reckon. drain the tank and give the surrounding area a good sand then smack it with a ball hammer so you have a little cavity to fill up with the knead it.
henderson_guy, Feb 4, 5:04pm
If the knead-it doesn't work, it may be better to look into another tank rather than to get your one welded up, as a pin hole could be indicitive of bigger problems, such as thin steel due to rust.
msigg, Feb 4, 5:10pm
sealer and plate screw or rivet.
purple666, Feb 4, 5:46pm
Araldite works fine for petrol tanks
budgel, Feb 4, 5:55pm
A cake of slightly soft yellow sunlight soap makes a good temporary repair.
morrisman1, Feb 4, 6:03pm
That sounds about as permanent as the schit that sticks to John Key
craig70, Feb 4, 6:06pm
Thanks for that have done temporary fix with soap. It looks like pervious owner has used some kind of red gasket like glue on it.was trying to avoid emptying tank so may take it out anyway and get it looked at. Thanks everyone for your help:)
jmma, Feb 4, 6:16pm
yup +1
chopper14, Feb 4, 8:50pm
Quotehenderson_guy
i would have to agree
jono2912, Dec 9, 11:40am
Chewing gum is a good temp repair, sets hard when in contact with petrol, or at least it used to!
