Faulty fuel filter?
hoarder85, Nov 12, 12:37am
Hi all, replaced the fuel filter in my 2005 Hyundai getz (internal tank filter) with an aftermarket filter and the car wouldn't start. Fuel was definitely pumping through it, and there was no air in the fuel line.
In the end we put the old filter back in and the car started first pop. What are the chances of the filter being faulty? Or is it more likely to be installer error?
intrade, Nov 12, 12:56am
what make was that filter?
hoarder85, Nov 12, 2:23am
Transgold is the brand.
martin11, Nov 12, 3:28am
Check the sizes I had problems with an aftermarket fuel filter and it turned out it was not the correct size for the vehicle .
kazbanz, Nov 12, 4:09am
No chance theres some sneaky unique item on the factory filter ?
alfred011, Nov 12, 9:43am
factory one might have like a one check valve built into it .
intrade, Nov 13, 5:53am
transgold ,, sounds a bit like stuff from one-hung-low factory products .
franc123, Nov 13, 9:27am
What was the reason for changing it in the first place? Intank filters aren't normally a service item.
lk104, Oct 21, 9:02am
That's gold!
