On the way home from work tonight I noticed the clutch pedal was making a noise when pressed in and when released.Hard to describe the noise, a funny squeak or noise like spring being stretched.It's a cable type clutch not hydraulic.Is it just a squeaky hinge that needs lube or is something funny happening to the cable!
Also, if the cable breaks, will the clutch be engaged or disengaged!
foxdonut,
Sep 16, 4:55pm
DId it change gear okay!
Mate had a Familia that made all sorts of noises but worked fine - it was catching on a bit of plastic stickking out of a floor mat or something like that.
bjdw,
Sep 16, 5:01pm
Yeah, it's working fine.
mileyfan73,
Sep 16, 5:04pm
Cable won't break.Common problem,especially in old work utes like Nissan Navaras etc.Try spraying some Siliconup under the dash on the spring mechanism,otherwise a mechanic may have to delve deeper into it to fix it.Not a major,just a nuisance!Clutch will keep working fine.
the_don_61,
Sep 16, 5:23pm
They do in vauxhall victors.real mother to replace. Cut hole in firewall is easy way . my Nissan Navara hasa hydro clutch
bjdw,
Sep 16, 5:41pm
It's a 94 Sentra.Thanks.
marte,
Sep 16, 5:59pm
I had a huge loud squeal come from the gearbox once, pulled over & called up a guy. We came to the conclusion it was a broken spring making its way out of the clutch plates. I kept operating it till the noise stopped. Later I noticed the pressure I needed to operate the clutch dropped & everthing was still Ok, so I guess thats what it was.
A loud scraping noise while slowing down is a faulty thrust bearing.
A wierd vibration that comes up thru the pedal & changes allmost everytime i pushed the pedal turned out to be a buggered spigot bearing (little bearing inside the clutchplate) on the first motion shaft (shaft sticking outta the gearbox) $10 part haha. Much sweating bricks for a while. Swapped da gearbox too as I couldn't replace the shaft for cheaper.
Sep 16, 6:03pm
Fixed.
bjdw,
Sep 16, 6:31pm
This noise is not very loud and definetly inside the cabin.
bjdw,
Oct 30, 4:04am
Cheers, will try some silicone.
