I've done a few but that was back in the 70's. Still got the flywheel puller.should sell it on here.
toybox,
Oct 2, 5:28pm
Have broken the ball on the bottom of the clutch lever arm, our Mini is a 1980 LE, Have managed to get hold of an arm from a 1972 model, the arm is straight.On our one ithas a crank in it.The ball does not want to fit into the collar in the main shaft that goes into the clutch housing.Question. does anyone know if they changed the size of the ball between those years! cheers
Oct 2, 5:33pm
No they should all be the same, the clutch used between 1964-82 was identical, it was only changed in 1982 to what the poms call a Verto clutch which used a shorter lever, the verto clutch basically means around the way that it should be, ie with the plate and pressure plate on the outside of the flywheel.The levers were prone to bending over time.
Dec 3, 5:05am
Is it a good solid one!I might be interested in buying if you list it.
