Looking idly at these (Passat/A4, mainly) - just want to know if the 4Motion system is the same as the Quattro system, or did VW get a cheaper version!
TIA
vtecintegra,
Sep 15, 7:30pm
They're just marketing terms and don't refer to any specific system, there are different versions of both available
neo_psy,
Sep 15, 7:43pm
Oh, really! Hmm, that's likely to make it more complicated.
Thanks for that.
thejazzpianoma,
Sep 15, 7:58pm
No its pretty simple really. If you are looking at 1995-2005ish vehicles they all use much the same 4th generation Quattro system. There are no cars in the range that will significantly out perform others in terms of4WD capability.
Quattro, Syncro, 4Motion are all names for much the same system.
neo_psy,
Sep 15, 8:09pm
Cool, thanks Jazz.
Will be back to pick your brain, I suspect.
thejazzpianoma,
Oct 28, 8:17am
Thats fine, they are great cars. Just be weary of the A4 if you are looking at prior to 2001. The Passat before that date is a much safer as the Audi is the last of an old body shell and it lacks in the NCAP safety tests. There is a very good value Passat Syncro 2.8 on here at the moment for about 5K if you have a look.
