What tyre pressure for
likit, Oct 6, 3:38pm
a Ford Courier ute with 185 R14 gt radials,thanks.
mrfxit, Oct 6, 3:44pm
Depends partly on exact model & year
Base pressures
unladen
32psi front
28psi rear
Moderate to fully loaded
35psi all round
likit, Oct 6, 3:47pm
2002 T/Diesel,they are commercial tyres & I'm sure my son said when he went to check them they were showing over 60 on gauge
mrfxit, Oct 6, 4:09pm
Whewww, must have been 1 heck of a load on the tray
mrfxit, Oct 6, 4:16pm
Would still stick close to my suggestion.
Upwards of 40psi for fully laden (saggy bum load)
Maybe 35psi front depending on how the tyres wear & how it feels.
Partly also depends on where & how you drive.
Theres a few varibles to consider but the above is a good basis to start with.
Eg:
I have a Hilux Surf on 265/70/15" AT's
Some ppl insist on 35 to 42psi for teh same vehicle & tyres but my surf runs well & has very minimal wear at 38psi all round
a.woodrow, Oct 6, 4:26pm
When I first started out in the trade, it was my job to load up the workshop trailer with scrap metal. when done the rims would be sitting on the ground due to weight, I would just pump up with air to get the metal rim off the ground usually 60-70psi. (on boss's instructions)
PS don't forget to let the air out again when unloaded
fryan1962, Oct 6, 4:32pm
has very minimal wear at 38psi all round,,,mr fix it .for me 38psi is good as well
unbeatabull, Oct 6, 4:45pm
We run 36-38 PSI in the couriers we service at work. In fact pretty much all modern Ford Vehicles are around that pressure range
mrfxit, Oct 6, 4:48pm
Same vehicle & tyres .huh!
Yea, 2 years ago, I fitted 2 tyres on the back with about 2 maybe 2.5mm of tread, been all over the north island/ part way down the south island & clocked up about 15000kms.
Blimin bridgestones are still about 2mm.
Fronts the same depth & wear rate but a harder compound & different brand.
mrfxit, Oct 6, 4:51pm
Whats the km's you get out of your fleets tyres & what part of the tyres wears out the most 1st.
Do you get a lot of center wear on the back
unbeatabull, Dec 12, 10:03am
We don't tend to, we rotate tyres every service though which could minimise it. We get the odd one that carries a lot of heavy stuff around which wears the tyres a bit harder but generally they were pretty evenly.
Centre wear is generally caused by too high pressures though
