Tyre pressure. Can someone tell me what the pressure should be on a toyota camry swagon thank you
pericles,
Mar 8, 9:35am
can someone tell me what the pressure should be on a toyota camry s/wagon. thank you
robbo36,
Mar 8, 10:41am
Should run between 32 and 36 psi in them. You could run 38 psi in the rears when loaded.
pericles,
Mar 8, 10:50am
thank you, stupid partner had them at 26, told him it wasn't right
jasongroves,
Mar 8, 10:52am
There should be a sticker inside the drivers door jamb with tyre info on it. Start there and adjust accordingly. Only info I have is for the sedan and that says 31psi front and 29psi rear, but it will depend on the load (as above) and the type of driving you do.
pericles,
Mar 8, 10:53am
mostly town inside the door is in Japanese
vtecintegra,
Jun 29, 3:07am
Still pretty easy to work it out what you should be looking at, although the number is unlikely to be in psi
My car says 200kPa/2bar which is about 29psi, but I tend to run a bit higher around 33psi or so
