The tailgate release on my Falcon Wagon has just started making a graunching noise when the button is pushed either on the dashboard or the remote. Door opens ok but sounds really loud and goes for about 2-3 seconds. Is it a broken spring in the system! Any advice on how to fix for a fairly handy old coot! Thanks.
marcos1,
Oct 27, 5:26pm
I just replaced one on a Ba sedan today,with the same noisy problem .Get a second hand one.
mowerman99,
Oct 27, 5:58pm
Thanks. What parts are involved! Is it just a matter of removing the tailgate liner and there it all is!
unbeatabull,
Oct 27, 6:17pm
Its the actual actuator, about 10 mins to replace, just a case of removing the trim and I think its 3 10 or 13mm bolts and a plug
marcos1,
Oct 27, 6:17pm
Remove the tailgate trim , and the catch is located by two 10mm head nuts and the plug in connector. IIRC, the s/w has a separate actuator, as opposed to the sedan which has a built in sealed unit.
grangies,
Oct 27, 6:22pm
Complain to Ford that it's just not good enough to have these problems only 8-9 years since new.
Same goes for the niggly Holden problems.
mowerman99,
Oct 27, 6:50pm
True but they do happen and it's great to be able to find out how to fix em on here. Thanks guys
4piggy,
Oct 28, 8:52pm
common for these actuators to play up,you wou be better to fit a universal central lock motor and it would be cheaper to buy than s/hand factory one, ive fitted several in the past
mowerman99,
Nov 15, 7:53am
Hi 4piggy Still havn't got around to fixing the tailgate actuator (just useing the key at the mo) so where would I source a uclmotor and how much would I be looking at paying! Thanks
mowerman99,
Nov 15, 3:26pm
Bump 4 4piggy
