Filling oil up on a 1998 ford falcon forte sw
smith165, Dec 18, 2:04pm
cant figure out how to fill or check the oil on our car
and check the sutomatic levels
therafter1, Dec 18, 2:10pm
16mm bung on the R/H rear of the trans.
mellisa2000, Dec 18, 2:36pm
As above. There is no dipstick. As above. You need to undo the bung, rear r/h side above exhaust bracket. Remove said bung, the fluid basically should drip/come out, then level is ok. To service,drop pan and replace filter, then refill level through bung. Arse of an idea. A full trans flush is recommended, (May take up to 16L of ATF) and realistically easier to have a shop do it if you can spare the $$.
mugenb20b, Dec 18, 5:47pm
Easy. Open the bonnet, and you'll see a dipstick by the intake manifold, it's yellow. Make sure the engine is not running and vehicle is on level ground. Pull the dipstick out and wipe it clean with a cloth. Insert the dipstick as far as it goes, and pull it out again. The level should be between the low and full marks. If the level is at low or below, add 1 litre of oil and check again after 30 seconds. The engine oil is filled through the oil filler cap, which is on top of the engine near the front of the rocker cover.
unbeatabull, Dec 19, 5:12am
98! AU I'm guessing!
They take 5.5L of Engine Oil, dipstick as mentioned is by the intake manifold.
brokebloke1, Dec 19, 5:45pm
AUFalcons dont have transmisson dipsticks just do what poster #3 said .
the.wife, Dec 19, 5:47pm
Read post 1 again.
mellisa2000, Dec 19, 5:57pm
OK check level of engine oil with dipstick. If you don't get that, then get a taxi.
panicky, Dec 19, 7:10pm
Need to use TQ95 or 95LE in these not DX111
rovercitroen, Jun 21, 4:17am
Is it checked with the engine idling or not! Very important if the reading is to be correct.
