Im Back! Your Honda Specialist
Page 6 / 6
antwerp87, Jul 31, 11:05pm
Ok. This is an interesting one. The Thermostat shouldnt make too much difference. If its doing it warm and cold then thats not the issue. Now the Trans Fluid type may be an issue as might be the torque converter itself. I would like to find out pressure tests etc to see where things are at with your car. That would be my starting point.
Please get back to me as to everything you know about the problem so far. Temperatures its been happening, frequency, when the trans fluid was last replaced, with what type of fluid etc. Thanks
sxcstar, Aug 1, 12:04am
I have a 1996 Integra Coupe with the 1600cc motor. The temp gauge has stopped working, where on the engine is this connected to! Thanks
stevexc, Aug 1, 6:20am
Hi,
It will never engage when cold, but it will sometimes engage when warm.Especially if I briefly stop the engine.
I've personally drained and refilled the transmission twice (1000km apart) with genuine Honda ATF.So assuming 50% drains out each time, the transmission now contains 75% new ATF.
antwerp87, Aug 2, 9:56am
Ok its definitely not atemp problem (coolant temp) Im thinking It could be a solenoid problem. I would be taking it in and asking for a pressure test of your trans. If gears arent engaging that is a main thing. It will always go into reverse as that is a teeth gear not a clutch pack.
stevexc, Aug 2, 10:51am
Thanks antwerp
There is nothing wrong with the main drive gears, it's smooth as.I'll check out the two solenoids that control the torque converter lock cheers.
ninja_man, Nov 7, 3:31pm
Hi, im about to do an oil change on my integra type r. Would you recommend a semi or full synthetic oil! cheers
drew2009, Nov 21, 8:44am
Hey antwerp87 are you still around i got a few questions!
rta777, Nov 22, 9:19pm
Me too. :)
Are you there ant!
(BUMP)
angel_25, Nov 22, 9:27pm
Just use Rice Oil
ninja_man, Nov 23, 6:29am
nice pod filter you got hanging out of your sti. ricer
hijacka, Nov 23, 12:54pm
LOL SNAP!Bugger it! was wondering how long it will take you to click.I didn't actually think i was logged in under my misses user name when i posted that haha. it was fun pretending to be scotty20001 for a day ;) and yes i actually like Hondas! but truth is Subarus aren't ricers ninja;)
ninja_man, Nov 23, 3:41pm
haha.
hijacka, Nov 23, 3:56pm
Hey ninja, at least scotty20001 got the send off he deserved.( a deleted one) haha
ninja_man, Nov 23, 4:12pm
yup. Hope he doesnt come back for a while.
drew2009, Nov 25, 9:36am
Seems ants is MIA
drew2009, Nov 25, 9:38am
As for your oil ninja_man, you live fairly far north so temperature isn't so much of a consideration. How many km does your integra type r have on it! What were you using before viscosity wise!
_frodo_, Nov 25, 9:42am
antwerp87; my 2003 odyssey ra6 (2.3) sets off the abs in the front left with ordinary braking (feel a slight shuddering as it pulses and can hear the pump).Its not throwing any codes, and the light comes on and goes off as normal on start up.What could cause that!
rta777, Nov 27, 4:16am
Indeed. come back ants - all is forgiven.lol
And: we need ya.:)
/ [bumps]
snoopy221, Jun 25, 8:07pm
Just a query on behalf of antwerp.
er(V)
OR er(G)
Suspect ERG.NOT ERV.
snoopy221, Jun 25, 8:11pm
Thought so.LOL
(Just makes it easier for antwerp)-K
