El wagon no reverse
sandyelmo, Nov 24, 2:58pm
Hi does anyone have any suggestions as to why my ford el wagon has no reverse,
thejazzpianoma, Nov 24, 3:14pm
Didn't tick that option when you bought it!
countrypete, Nov 24, 3:32pm
Someone swapped the box for a DSG - usual result!(sorry - couldn't resist)
unbeatabull, Nov 24, 3:49pm
Does it still have all other gears!
Auto/Manual!
If Auto, could be a band, or servo, or clutch packs . would need to be stripped either way.
sandyelmo, Nov 24, 4:00pm
Its an auto, will an ef2 floor change tranny fit el column change!
unbeatabull, Apr 5, 9:40pm
Depends if it's same trans. I'm assuming 4 speed! If they are both the same trans then yes they should, will have to swap over the linkages etc though
