door panel and the metal door.Does it need to be there!Why is it there!
vtecintegra,
Jan 20, 11:31am
To stop moisture inside the doors from affecting the trim panel
lookoutas,
Jan 20, 4:36pm
And to direct water back inside the door where it can exit at the drain holes - instead of finishing up inside the car. And wrecking the door cards.
bjdw,
Jan 20, 4:39pm
hmm, i cut holes for the magnets on my speakers.I suppose they will get wet now.I also put crossovers in the bottom of the doors.Sounds likw they may not last long.
opencast,
Jan 20, 4:39pm
Not to mention awful drafty without it.
rob_man,
Jan 20, 4:39pm
And prevent draughts and dust. If yours has fallen apart while you were taking the trim off you can cut a new one out of plastic and stick it on with duct tape.
rob_man,
Jan 20, 4:42pm
That's a wet area, you can position plastic over the inside with a bit of perseverence, it may help. Factory speakers have plastic covers on the inside nowadays.
lookoutas,
Jan 11, 12:02pm
That's what I would say too.
