Not strictly motoring but anycaravan owners out there know where I can find a plumbing diagram for this,its a 5.67m 1981,has been completely gutted and I am now in the process of refitting(shower has been taken out) Have searched the net but no luck.
cuda.340,
Nov 27, 6:42pm
what exactly are you wanting to know!i've done a few caravans up & there ain't much to them. not hard to figure what goes where.
frank1,
Nov 28, 3:15pm
OK--hot water cyl is under bed,1 inlet,1 outlet-outlet has regulator attached,with drain off--well I think it should be on outlet-so if prob occurs water will be pushed out overflow,2 outlet pipes on underfloor water tank,guess 1 goes to hot water cyl and other to cold tap. Guess my question is does cold water feed to fill hot water cyl also branch off to cold water tap on sink. Am I right! If no hot water cyl fitted im sure I could figure
frank1,
Nov 28, 7:10pm
cuda
goron56,
Apr 18, 4:12am
Yep the cold tap feed keeps the cylinder full as well.
