Timing belt. Just broke timing belt on a toyota hilux will it damage engine some one said it should be sweet cause its a toyota
pacificsand,
Apr 17, 5:48pm
To add to timing belts, I just had my Hilux in for what I thought was a head gasket problem 1.5k to fix to find out it it's a loose timing chain causing damage to it's housing and is up to 3k to fix. Does this price sound reasonable !
a.woodrow,
Apr 17, 5:55pm
Will be almost guaranteed to have some level of engine damage. Could be minor (I broke a belt in a 2l-t once and only needed 3 new cam followers) or it could be bent valves, damage to camshaft etc etc. You'll only know when you strip it down.
gadgit3,
Apr 17, 5:57pm
22R!
dent,
Apr 17, 5:59pm
what engine is it pacificsand and what was the original fault!
pacificsand,
Apr 17, 6:07pm
Yeah 22R, Hi Dent. original fault was water in the oil. Head Gasket has been looked at and fine. Since found out it is a loose time chain causing slight holein the casing causing the problem.
incar.,
Apr 17, 7:08pm
Interference motor
jmma,
Apr 17, 7:13pm
These also corroded with lack of inhibitor, Not really a huge job, 3K sounds excessive, but have they taken head off, Is this included in price!
pacificsand,
Apr 17, 8:49pm
Yes, the head has been removed and taken in for a check, and included in the price, cheers
ceebee2,
Apr 18, 2:42pm
Give Gleye and Parlane a call in Barrys Point Rd Takapuna and get a quote from him.he is the best diesel repairer / auto machinist I have known in Auckland and genuine no rip off. Tell him CEEBEE Mtrs referred you. Sound very expensive to me.Will even be worth transporting it from Warkworth.
gadgit3,
Apr 18, 2:58pm
22R is a petrol.
ruralben,
Dec 4, 8:01pm
just broke timing belt on a toyota hilux will it damage engine some one said it should be sweet cause its a toyota is this write!
happylad3,
Dec 4, 8:57pm
Nope. Sorry to say, it will be toast. Bent valves, broken buckets and shims. Possibly even a cracked piston if it hit hard enough. And at a stretch, cracked cam.
Edit: to say that applies for an "L" series and the 1KZ engines
ruralben,
Dec 4, 8:59pm
but its a non interfering motor!
happylad3,
Dec 4, 9:05pm
What engine have you got!
jasongroves,
Dec 4, 9:06pm
x1
Save me Jeebers
ruralben,
Dec 4, 9:18pm
5l .3ld 2001 toyota hilux
happylad3,
Dec 4, 9:22pm
It will be very most likely rooted. On those the valves are flash with the head. And when the belt breaks, so do a lot of other things. Just had a 5L at work that broke a belt. And it needed 8 valves, 8 guides, and new cam and followers.
the-lada-dude,
Dec 5, 5:58am
jezz that was lucky, what's that gunna cost to fix !
the-lada-dude,
Dec 5, 4:41pm
well !
happylad3,
Dec 5, 4:54pm
Shit sorry. Didn't realise you were talking to me. I have no idea of the costs. I'm just the boy that does the work. The office sorts that shit out.
the-lada-dude,
Nov 13, 8:52am
don't be sorry , just ask the boss or rummage thru their paper work and let us know.
