Yours should match one of those, the positive and negative colours are the same either way.
jasongroves,
Jan 27, 5:44pm
It says its a switched 12v, so I would assume it would save your pre-sets etc.
jasongroves,
Jan 27, 5:54pm
Test it first if you like. All you need is a test light, multi-meter or even an old head light or brake light. Test for power with the car switched to acc and with it off. I'm guessing the switch works only when there's a load on it, so that should answer that question without too much fuss;)
saxman99,
Jan 27, 9:25pm
If your constant 12v supply is gone, it's real easy to splice off the cigarette lighter feed instead. ( should be always on in that car)
