Tyre Size recomendation!
ginga4lyfe, Dec 5, 6:50pm
I have a set of 16x7 'sfor my caldinanow, and although the offset is about 3mm off ( should be max 45, but is 48 ) they will fit nicely with minimal rubbing i guess, Now as far as i can tell I should put 205/45 R16's on the rims to suit the new rolling diameter, with the 205/45's i should only have a difference of .8% faster speed on the speedo, can anyone else chip in! a friend reckons that 195'50r16's should be put on, But thats a 5% difference on the speedo and im not too keen on those, so whats anyone elses opinion!
vr4_legnum, Dec 5, 7:19pm
what size/rim's is on the car at the moment!
ginga4lyfe, Dec 5, 7:24pm
they are the standard 185/55r14 's Opps I ment 185/65r14
clark20, Dec 5, 7:42pm
vr4_legnum, May 5, 2:48am
If it was me, I would probaly go with 225/45r16. It only work's out to be 2.15% bigger then the 185/65r14.
But 195/50r16 would be the right size to go with
