my low beam head lights keep blowing the fuse i put a new one in then bang sum times it lasts for 10mins thensum times two days any help please thanks
Nov 7, 5:40pm
You might have a wire that's rubbed through somewhere, touching the body, creating a short circuit. Trace the wires from the headlight back, and see if you can find any bare, rubbed through wires.
the-lada-dude,
Nov 7, 5:59pm
i had that problem with my bently , so i ajusted the lights so on hi beam they looked like low beam, hey problem solved
burnzrubba,
Nov 7, 6:14pm
yes but will that pass a wof like that!
Nov 7, 6:15pm
No, and I'm pretty sure he was taking the piss.
xs1100,
Nov 7, 6:19pm
could be headlight switch
the-lada-dude,
Nov 7, 6:41pm
would i do some thing like that !
hey mugenbi still cant get the top of that pump !only held on by 4x c/ screws but appears to be stuck on location dowel in top right cnr. will probably get more athletic with it tomorrow.
Nov 7, 6:52pm
Really! Try a light tap with a small hammer from the side. As for the vacuum hose that goes to the diaphragm on top of the pump, the other end needs to go to the boost side of the turbo (looking at a turbo charged Mitsi 4D56).
burnzrubba,
Nov 7, 6:53pm
thanks will check it out tomoro
owene,
Nov 7, 9:31pm
Put a bigger fuse in then.
burnzrubba,
Nov 8, 2:39pm
I have done that still BANG thanks
cypherboy,
Nov 8, 4:20pm
WD21 Model! If so then the headlamp switches do play up on them, also seen a couple that had a short and melted the plug for the bulb.
burnzrubba,
Nov 9, 8:31pm
think so its a 1989 v6 where do i find the headlight switch thanks
snoopy221,
May 9, 9:04pm
where do i find the headlight switch (o:
Babel fish translation. um it's that damn thang by the steering wheel with indicators and headlights on it ya know The **switch** that turns em on. Moit pay ya to take it to an auto sparky.
