Mazda 626 using oil. Hi i have a mazda 626 year 2000 which is using oil compression test was all at 175 psi we have replaced the
rhonda211, Dec 12, 6:05pm
Hi, I have a mazda 626 year 2000 which is using oil. Compression test was all at 175 psi, we have replaced the oil filter and use 20/50 oil. It is not blowing smoke, and not leaving oil on the ground. Car appears to being running ok. Any ideas as to why it is using oil!
mugenb20b, Dec 12, 6:07pm
No, start another thread.
winch1, Dec 12, 6:10pm
Nothing wrong with any car using a bit of oil.
When its using a litre every 500ks it can still be ok.
a18a, Dec 12, 6:11pm
to lubricate all the stuffs inside the engine
mrfxit, May 30, 6:17am
Could be getting sucked back through the EGR systems / valve stem seals / weak piston oil control rings /Pcv valve fault & burnt in the cylinders at a small enough rate that you don't see any smoke when looking in the rear view mirror
