Transfer case oil!
perry111, Dec 17, 6:26pm
i have a 1996 mitsi vr4 it is wining when cruising at 100kmh like a syncro is fucked lol i i checked the transfer case and nothing came out,what oil is the best 2 put in and how much does it hold! thanks
mugenb20b, Dec 17, 6:40pm
A worn syncro won't cause whining noise.
mugenb20b, Dec 17, 6:41pm
How did you check it! Through the filler or drain plug!
perry111, Dec 17, 7:09pm
through the filler plug.and put mi finger in and it wos pretty much dry
andy61, Dec 18, 7:23am
Adding oil wont fix it now.
perry111, Dec 18, 7:24am
done sum damage u rekon!
elect70, Dec 18, 10:11am
^^ just a bit , throw some banana skins in it & flog it off
ralphdog1, Dec 18, 1:20pm
Bit like putting on a condom afterwards.
phillip.weston, Dec 18, 1:52pm
if it's a 2.5 new shape VR-4 the whole center diff and front diff assembly are incorporated as one, whereas on the earlier 2.0 which were made up til 96 had just the transfer case separate. Either way you can just swap on another transfer case, with the 2.5 one being more expensive.
perry111, Dec 18, 3:16pm
its a 96 gearbox oil is seperate.
phillip.weston, Jun 17, 5:12pm
yes but both the 2.0 E74A/E84A old shape and the 2.5 EC5A/EC5W were made in 1996. And both have transfer cases separate to the gearbox, it's just in the 2.5's the front diff is also housed in the transfer case too.
