cant get the darned thing to engage, bugger of a thing (350 Chev), put shim in and it just spins freely, take shim out and it sounds like it it is hitting flywheel, arrrghggghhh
bigfatmat1,
Feb 8, 7:21pm
sounds like that solenoid cap was assembled wrong.
mellisa2000,
Feb 8, 7:32pm
New starter/reco'd! From that vehicle originally! Sounds like you need the shim removed, but the teeth are not meshing. Correct Gear on starter!
mk3zephyr,
Feb 8, 7:58pm
exactly the same starter as was in it, best i wait till the reduction starter turns up
ginga4lyfe,
Feb 8, 9:20pm
Does the starter throw its gear out properly on a test bench! and have you stress tested it on the bench! ( with a piece of wood ) its noo good if the return spring is too tight to throw the gear out properly
