changed battery now abs,vsc and handbrake lamp on.went to reset on carman scan(tool) gives error code c1345 not learning linear valve offset abnormality, any ideas on manual resets as according to good old toyota site it can be reseted by thier machine only
reaperssoul,
Feb 10, 5:58pm
the big one
bigfatmat1,
Feb 10, 6:19pm
bridge pins 4 - 13 of the make the car READY and depress the brake pedal 8x in five seconds but at a rough guess you will need to perform linear valve learn value intialization off to the dealer I think only their scantool can do this good luck not sure bout carman scantool check under abs menu
reaperssoul,
Feb 10, 8:23pm
thanks, will try that and i made a mistake the vehicle is ESTIMA HYBRID not prius
Feb 11, 7:46am
there is prius hacker forums i suggest you vistit one of these sites.
Feb 11, 8:56am
you can drive them they got a 1,,5 petrol engine. but i have not seen crazy cheap onesyour crazy cheap and my one are probably a different one .
reaperssoul,
Feb 11, 5:50pm
figured it.just needed to calibrate the system using the scan tool
bigfatmat1,
Feb 11, 6:34pm
sorry did i not make my post clear enough this is what i said in my post lol
reaperssoul,
Feb 11, 7:18pm
thanks,
but i checked in my scanner their was no option
but i actually talked to a guy who works at sulco,he came with a different scanner and we did it from their as his scanner was more up for the job,he was probably the nicest/helpful bloke i had met in a long time
