My dirt bike keeps bottoming out every time i land a big jump, i was thinking my suspension was to soft. Not sure any other ideas to what it might be!
pettal,
Dec 22, 7:17pm
too bigger rider and too smaller bike !.
wackmac,
Dec 22, 7:28pm
Could be your approach to the landing. Downhill, uphill, or flat landing! Front wheel first! Rear wheel first! I tend to get a better landing with the rear wheel hitting the ground first. Takes a bit of the impact out of it.
glenn_michelle,
Dec 22, 9:06pm
if every other aspect of how your bike handles is fine i would leave it as is,if you set up the suspension to suit landing jumps then it will adversly affect other areas,jumps are such a small part of riding its not worth setting up for it unless you do mx!
muzz67,
Dec 23, 4:47am
90kg on a pitbike will always bottom. 40kg on an mx will never bottom. need more info.
sr2,
Jul 4, 4:16am
Check the static sag and dial in more pre-load if required. Increase the compression dampening but make sure you test it for ballance on a good set of whoops first!
