It is a EJ20 twin turbo , has dip sticks on either side of the tranny. When going along it seems to stick in the same gear and have no power, and shudders a bit at about 50kmh sometimes, does this mainly when cold , or when its been switched off for a hour or so. Checked the dips sticks , it appears to have clear/yellow oil, smells like engine oil , not red like normal.
bevharris1938,
Feb 10, 8:23pm
Car is low kms , only 118,000 1999 model
loonee-dial-111,
Feb 10, 9:16pm
The short dip stick on the left is yellow front diff oil, the long dip stick on the right is red atf. Is your AT hold switch turned on.
vtec101,
Apr 7, 2:04am
bump my 1999 non turbo legacy does it 2
