What is the most suitable engine oil for these ! I have used Magnatecin the past for EJ20T, EJ25T, SR20DE and 6A13TT. And they all have been running very well. But I have not had a V-tec before. Thanks.
ct9a,
Feb 14, 7:12am
mobil 1 gold,keep an eye on the level oil
ginga4lyfe,
Feb 14, 10:40am
why! a 10-15w to 30-40 would do just fine, and if its chewing through oil it will have a problem ( probably because ur using a very light oil )
richardmayes,
Feb 14, 10:43am
Did you buy just the engine, or do you own the car it was built for too!
ct9a,
Feb 14, 12:16pm
because its a high strung 4cyl with high compression. they use oil,does not mean there is anything wrong,you wont see any smoke etc,also need a good oil for the chain and tensioner.
dont buy a performance car if you carnt afford decent oil every 5k or 95+ octane petrol.
here is a article that may fill people in that assume its a run of the mill jap engine.
vtecintegra,
Feb 14, 12:34pm
Its a family of engines, and yes at the low end they are run of the mill
smoothgroove,
Feb 14, 2:50pm
Hi, it's the K20A in the CTR. Complet car.
richardmayes,
Feb 14, 3:05pm
Cool - and obviously you're asking us here because the car's handbook is missing.!
shane.64,
Apr 17, 2:05am
Like everything else the more money you spend the better oil you get !
