Hi Gents. My VP Crummydore runs like a dream. Untill i turn right, the engine either starves or stalls [doesnt conk out] any idea which sensor or something that may be loose!
sfw4,
Feb 13, 6:33pm
petrol pump on its way out! the idle revs abit high sometimes only when on hot long runs
countrypete,
Feb 13, 6:46pm
When did you last change the fuel filter near the fuel tank!I had a similar issue and that cured it.
johnf_456,
Feb 13, 7:09pm
Fuel related to me, check fuel pressure, leaks, pump.
sfw4,
Feb 14, 7:42pm
hey thanks for your help gentlemen. went to SCA got a petrol filter real cheap $11, installed it. also cleaned out idle sensor with CRC. it started getting dark so will test drive tomorrow
carkitter,
Feb 14, 7:52pm
I knew someone with a VL Commodore (3.0L Nissan engine) that would stall when going round corners after a service. Turns out the Coolant reservoir was overfilled and excess water would spill onto the distributor when turning corners.
sfw4,
Feb 14, 8:03pm
Interesting. reminds me i havnt check the Automatic fluid in about 5years!! when going around corner the fluid may not be enuff for the torque coverter seeing it may be 1/2 empty ay
johnf_456,
Apr 18, 9:47pm
Cunning
