Rvr gear box number !
d.a.reid, Feb 15, 3:14pm
hi my mitsy rvr needs a new gear box but tosource a new one i need the gear box number does any one know where i can find this number
cheers
jasongroves, Feb 15, 3:20pm
Have a look under the bonnet on the VIN plate:
http://labelling.fuelsaver.govt.nz/gfx/jmc_mitsubishi_lancer_1.jpg
You are looking for the trans/axle code.
andy61, Feb 15, 3:47pm
Good luck getting a replacement gearbox,every other RVR needs the same thing.
franc123, Feb 15, 3:57pm
+1, lol you just beat me to it, if anything the number being sought here should be 0800 SENDITTOTHECRUSHER.They're all stuffed and everybody wants the cheapest way out ->expensive 2nd hand gearboxes if you can get them.
yogibearz, Feb 15, 5:06pm
yes they are hard to get,the numbers are stamped into the top of the casing, Something like W4A32 then a few numbers, you MUST fit one with exactly the same numbers. Dont be convinced by a wrecker that this is ok and will do the trick. I have seen more than one have to be pulled out again after fitting and finding some small difference.
phillip.weston, Apr 21, 5:14am
I didn't have much trouble getting a replacement transmission for my one! only cost $350 from a wrecker including transfer case, and it was a recently rebuilt unit too.
