Ford Mondeo 2002 model
drsox, Feb 13, 6:14pm
How reliable as a car! I am thinking of buying one. Thoughts!
fordcrzy, Feb 13, 6:37pm
great cars. justa few things to look for.
tapping/fluttering noise from engine which is intake butterflies on the way out$$$$$$
also aux belt tensioner is problematic but cheap and VERY easy to replace.(rattling at idle)
check that it get s up to temperature on a long drive. thermostats tend to fail open meaning they don't get to temp properly
check tyre wear. they are a pain in the ar$e to wheel align CORRECTLY
do a hill start with the car a few times and check the clutch isnt slipping. an abused clutch once it starts to slip will just keep on slipping. Cost about $2000-2500 to replace clutch.
check seatbelts arent frayed, they seem to do this for some reason.
jrlaw, Feb 14, 7:53am
Brakes, If it has done about 80-90,ooo look at the brake discs, could be warn to the limit.
welshdude, Apr 22, 2:50am
I bought an '02 manual Mondeo a bit less than a year ago and I am delighted with it. Mine is the sedan with duratec engine.
