Drive shaft is making a grinding noise when i jack up wheels and put in drive. Is this still safe to drive around! How costly will this be to replace! 1999 A32 Nissan Maxima ST
johnf_456,
Jan 19, 9:42am
Are you sure its not a worn out brake pad or wheel bearing! Depending on what it is, but I would say its not safe to drive around on. If you are unsure get it looked at
lmfao-,
Jan 19, 9:48am
You can hear its coming from the gear box end more then the wheel end.
a.woodrow,
Oct 4, 4:16am
Could be the diff or anything really - probably best to have diagnosed by a garage
