The gear box (manual) in my Nissan is stuck in reverse.Any one got any ideas what is causing this!
Mar 10, 6:51pm
Nissan.what!
wayne472,
Mar 10, 6:53pm
Pulsar
phillip.weston,
Mar 10, 6:59pm
selector fork. Must be a common fault cause I was just looking at a pulsar for sale which also had its box stuck in reverse.
androth2,
Mar 10, 7:04pm
Check the gear lever linkages are both still bolted up properly at the back of the gearbox as one may have moved and jammed the gear lever ,it may be ok in the gearbox .You will have to get right underneath and look while somebody else trys to move the gear lever.
toxicgreen.,
Jul 9, 12:16am
Move the headlights to the bac of car, tail lites to the front. follw yr headlights
