olds took their auto crv up a slippery slope, put in lowest gear, didnt make it. Was behind them and although front wheels were driving and spinning, rears appeared to be unpowered! Thought those things went into 4wd automatically! Doesn't seem to be any other buttons/switches anywhere.TIA.
clark20,
Mar 12, 7:03pm
Once the fronts break traction power is meant to be applied to the rears
Mar 12, 7:13pm
Although your old's CRV may well be a 4wd model, you are aware that not all CRVs are 4wd, right!
muzz67,
Mar 12, 7:16pm
Well, it has got a rear diff! Cheers.
Mar 12, 7:19pm
Thanks for letting us know!
socram,
Jul 13, 9:10am
May be a casing, but is there anything inside it!!Should there be a designation on the chassis numbers that tells you 2WD or 4WD!
