Delica diesel, brake problem
les37, Jun 29, 3:22pm
1990 delica,replaced,front rotors,calliper seal kits. ,pads,, rear shoes and wheel cylinders., new brake master cyl.problem is spongy pedal .going to floor, only when motor is running . any ideas,was thinking brake booster, did not have this problem before brakes were done
v8cougar, Jun 29, 3:36pm
pressure bleed them and chack the booster has vacume
thunderbolt, Jun 29, 3:37pm
Get some brake hose clamps from your local Repco/BNT/SCA and clamp all the flexible brake hoses to see if that fixes the problem.
If the pedal is now rock hard, take off one clamp of at a time to isolate the location of the issue.
les37, Jun 29, 3:46pm
has vacume, good pedal when motor is not running,when engine is started, pedal goes to floor
sred69, Jun 29, 5:22pm
its normal on these, the tandem servo and alternator driven vacuum pump do givea spongy feel but if you drive it brakes work great, its just if sat stationary with foot on the brake it gives such good brake assistance it does feel spongy.
intrade, Jun 29, 5:23pm
yea but his goes to the floor lol.
les37, Jun 29, 5:25pm
$80 from autostop,had this problem after all brakes were done, so i then replaced master cylinder, problem still there
intrade, Jun 29, 5:26pm
i told you what to do. all the vaccume does is make it more easy for you to push the pedal nothing else
les37, Jun 29, 5:29pm
was pressure bled by mechanic, no fluid loss
mrfxit, Jun 29, 5:54pm
So .
It's ONLY when vacuum pressure is applied thats showing up a problem
Come on guys . THINK
strobo, Jun 30, 3:12am
uumm let me think !
strobo, Jun 30, 3:38am
clue(the adjustablelink betweenthe master ,reaction disc & pedal )
intrade, Jun 30, 5:04am
yea well you normally inspect if the new master is the same as the old. the vaccume sucks on the master. my guess is the new master is a Broken one also. that or somwhere is a leake letting air in I would clamp off one side of brake hose with vice grips then both and if its still going to the floor .also in the air check by hand when you can stop the wheel at what pressure on brake pedal needs 2 people.
strobo, Jun 30, 5:13am
intrade wrote:
yea well you normally inspect if the new master is the same as the old. the vaccume sucks on the master. my guess is the new master is a Broken one also. END .quote]
A broken new master cyl ! i doubt it, les alreadysaid it was pressure bleed by a mechanic .rear brakes should be adjusted up correctly
intrade, Jun 30, 5:16am
strobo i have seen loads of things dont forget one thing . all parts are made in china or taiwan these days that you buy in nz. I once had 1 brand new sparkplug that was faulty. man what a blimmin job till i figured it had to be that 1 plug that was new also . its not highly likely but possibile never the less
strobo, Jun 30, 5:18am
Ive never ever come across a broken NEW master cylinder.
intrade, Jun 30, 5:23am
the place who did bleed the brakes is where i would go and on to a brake tester roller machine to see if one of the brakes brakes less or more to then see if there is air in that one or a other problem and if all is ok i would remove the master again and fit a master from pickapart to see if that one does the same as the brand new one.
les37, Jun 30, 5:24am
this problem wasnt there until all brake parts, excluding master cyl were replaced, so master shouldnt be the problem
strobo, Jun 30, 5:26am
I suggest takingit back to who did the the job for them to see theirway clear in getting it right at no cost .cheers The pedal should only drop about an inch 25milapproxwith vacuum .motor running before it gets harder, not to the blardy floor !
intrade, Jun 30, 5:28am
hope it was not midas or pitstop you dont want to take it back there again thats sure as hell
les37, Jun 30, 5:30am
its a good mechanic, been using him for 10 years, its going back today. dont think anyone with half a brain would go to midas or pitstop
intrade, Aug 13, 7:45am
ok good let us know what it was its gota be something
