Hi guys, I had a starter moter reconned 5 months ago by my mechanic (he sent it to be done). Now the starter is not working again, he says because the solenoid needs replacing. Should this have been done during the recon ! not sure if I should be paying again for the same problem to be fixed. Cheers
supertech1,
Jun 28, 6:25pm
Type of vehicle! sealed solenoid!
badcar,
Jun 28, 6:34pm
2000 hiace van. No idea what type of solenoid
bigfatmat1,
Jun 28, 6:44pm
The solenoid is not replaced in a recon in a hiace very rarely do they pose a problem What is replaced is the solenoid contacts and the plunger inside the solenoid if the solenoid has failed it is simply bad luck.
badcar,
Jun 28, 6:50pm
no the solenoid was not replaced last time, my question iswhether it is normal to replace the solenoid during a recon while the starter is out to avoid having to do it again a couple of months later. Cheers
bigfatmat1,
Jun 28, 6:53pm
sorry my first answer was based on limited info you had given now I have correct info your answer is as above:-)
badcar,
Jun 28, 6:55pm
Thanks bigfatmat, thats what I was after. The recon says it needed bearings brushed and clutch- $365. Thought for that it might have been quite comprehensive. Thought I should check as the garage origionally said it needed a new battery- $200, then the recon when it still didn't start properly and now this new bill at $!
supertech1,
Jun 28, 6:58pm
Say it was a Porsche Cayenne V8 Hell yes replace the solenoid. Hiace easy, test bench ok It happens
bigfatmat1,
Jun 28, 6:59pm
Out of the thousands of Nippon denso gear reduction type starters I have fixed I have replaced maybe 3 or 4 solenoids. You normally just replace the parts inside the solenoid http://www.nationsautoelectric.com/densoparts.htmlthe housing with the lid off you see is the solenoid its case is part of the starter body inside that is a coil of wire which is the actual solenoid in your case sounds like what is being refered to
bigfatmat1,
Jun 28, 7:01pm
You would need to clarify whether they replaced the contacts in the solenoid if they did not this is bad practice for a $6 part as this could also be the problem because I am only guessing.
badcar,
Jun 28, 7:02pm
Thanks for your replies. Would it be necessary/normal to remove the starter motor to test/replace the solenoid!
badcar,
Jun 28, 7:17pm
Thanks for the vid link too- interesting!
bigfatmat1,
Aug 7, 8:48am
you can test in place to repair or replace is to remove
