VZ Commodore cooling/heating system
gary231, Jun 27, 5:58pm
Hope someone can help, I have a VZ - over the past 3-4 weeks it has taken ages (8-10k's) to get heat into the heater inside the car. Thought may need thermostat replacing. Now my wife has just driven the car abour 6 k's and computer starts beeping "overheating" and temp gauge up to red. I let cool for 10 min, removed radiator cap started engine and filled with water. It took about 2 litres, also filled the resivore (sp). Question: could the thermostat be staying shut as well as staying open or does this sound like a bigger problem! Thanks
berg, Jun 27, 6:03pm
Sounds like a leak somewhere. Take it to somebody who can pressure test system
gary231, Jun 27, 6:04pm
Thanks, that was a thought I did have - seem to have more condensation in cab than normal but have just steam cleaned carpets so had put that thought on backburner
berg, Jun 27, 6:08pm
Have a bit of a hunt round with a torch, both under the dash and under the bonnet. If coolant had plenty of antifreeze it might have left a visible trail to lead you to a possible leak.
gary231, Aug 1, 1:50pm
Thanks - will look in daylight
