motor-up, do it work! what about similar products that claim different things! ive seen an advert with an engine encased in a block of ice and it still started first pop using motor up. do these products really do whats claimed or is it just another marketing scam!
Jun 20, 6:51pm
Marketing scam. Just use good quality engine oil and you'll be fine.
morrisman1,
Jun 20, 6:54pm
The only additive I've ever noticed a difference with is a bit of two stroke oil (mineral/semisynthetic low ash) in diesel fuel. Reduces diesel knock substantially
jmma,
Jun 20, 7:05pm
I use power up in my Dyna deisel truck and I do get 40 - 50 km more from a tank full, I'm a believer in it as I see it with my own eyes
tnt423,
Jun 20, 7:29pm
How much two stroke oil do you run! I just started using it after my engine was running on a bit after shut down, so far it has almost stopped it only done it once in two weekd, it seems to run quiter as well.
sfw4,
Jun 20, 7:31pm
if its smoking put in half a tube of MP grease. banana peels in GBox stops the winding :p
foxdonut,
Jun 20, 7:38pm
I've seen that ice encased engine example too. While it looks impressive, encasing a motor in ice and starting it isn't really that big a deal - unless of course they filled it with water entirely, then froze it - in which case it would take a lot more than some Toulene / diesel, aka "Motor Up" to kick it over.
That would be a job for Marine66 / WD40 ;)
next-to-normal,
Jun 21, 9:16pm
motor up is very good stuff,more pep, less fuel,great for the diesel,takes about 400k to kick in,so do it on a trip,
morrisman1,
Jun 21, 9:24pm
I thinkI used 1:200, the car had a 70L tank so that would be 350mL of 2 stroke oil.
strobo,
Jun 22, 1:07am
Additives are not treatments, some are alcohol based & we allknowthat alcohol evaporates into thin air , Afuel treatment that broke down the molecular structure of moisture in diesel or petrol to help it dissipate through combustion, actually increased engine performance, so the theory went , that the moisturein fuel wasnt actually removed at all. but atomizedfollowed by combustion .Anadded treatment product that did 3 things, one was antioxidizing,two tolubricate,3toalter ppm. Agreat productI pushed years ago, with out naming directly here , isanMBL , ( Metal based lubricant) in the grease & oil range . http://www.fueloiltreatments.com.au/!gclid=CMmLyILdxKkCFQoGbAodfwNlNg
rovercitroen,
Jun 22, 6:21am
I have used Pro-Ma additives and they seem to be one of the few that really work. MBL8 cured a cold start rattle in my VR Commodore. The dealer had tried a few things (car had only done about 50,000 km) but no success. The MBL8 worked a treat. I have used Morey's oil Stabilizer to quieten and cut down smoke on an old engine. It works well but is basically just an oil thickener.
mrfxit,
Jun 22, 7:08am
LOLyea know the feeling, used to do stuff like that to my Briggs mower engines. Last 1 to die was 2 years lawn contracting & 6 years domestic usage after that. Only died because the top bearing & coil setup couldn't cope with the excess wear. Never touched the engine it's self in all that time.
ceebee2,
Jun 23, 2:44pm
Modern oil is well up to the task so no additives required. Save your money.
Cheers CeeBee (Auto Tech 30 years)
sirdoug,
Jun 26, 1:58pm
Motor Up is teflon based and you know how long that lasts on a fry pan.Don,t waste your money.
jason_247,
Jun 26, 5:13pm
while nulon 80000km engine treatment is PTFE based (polytetraflouroethelyne if i recall correctly) that is the new teflon
havent tried it myself
grangies,
Jun 26, 5:24pm
Oh dear Lord have mercy!
The one on the left has stuffed a baby camel's toe, in her knickers.
aktow,
Jun 26, 11:36pm
one day you might be heavy footed or do more city driving, that can add 40-50km more or less to your fuel mireage. even weight makes a hell of a difference.
snoopy221,
Jul 30, 3:16am
ive seen an advert with an engine encased in a block of ice lolread once that fish loses it's **freshness** when it goes below zero degrees and the BEST way to have **caught today** fish after being in the freezer for 6 or MORE months is to freeze it in a bag of water. WHY. BECAUSE ice does NOT go below ZERO and the **fresh fish** is kept ABOVE zero by the. BLOCK OF ICE IT IS FROZEN IN. P.S. if you don't believe this GO buy 2 fresh fillets-eat1 freeze the other for a MONTH in water. then well you WILL believe. LOL ah dear a BLOCK OF ICE.
