Cv joints. One of the cv joints on my car is getting quite bad about how much would it cost to get one cv joint done on a 1991 m
rthomas80, Jun 13, 1:07pm
one of the cv joints on my car is getting quite bad, about how much would it cost to get one cv joint done on a 1991 mazda cronos! tia
mugenb20b, Jun 13, 2:47pm
Usually between $150 and $200. Depends how easily they come off.
flockton55, Jun 13, 9:48pm
For my 88 323 FB, I just got used full shafts from a wrecker, 50+GST each
Easy to change.*
If you are quick, you can do the swap with minimal oil loss.
I had priced new outer CVs only at $95 each including.
You just need the big socket for the outer nut, and ideally, new nuts as you are not supposed to re-use them.
*Ask if you want a run-through.
rthomas80, Jun 10, 10:09pm
well have just had two quotes and both about $220
