Does anyone know who would stock a thermo switch for an electric fan. I want the one that screws into the bottom of the radiator. Don't want one that goes into the top hose.
for_an_angel,
Jun 8, 7:40pm
Auto sparky
bushells,
Jun 8, 7:44pm
Nup, tried a few and most of them only have the top hose model.
for_an_angel,
Jun 8, 7:57pm
Bugger. our local auto sparky holds a few different types of thermo switch.
sr2,
Jun 8, 8:45pm
You are right in not wanting one fitted to the top hose; if you fit it to the bottom hose or tank it will only turn your fan on when needed. These days I run the fans from the ECU but in the past I had great success with cheap 2nd hand Toyota senders from the wreckers. I??
bushells,
Jun 8, 8:49pm
Would you know what model of Toyota the switch came from.
for_an_angel,
Jun 8, 8:52pm
90-96 corona ran a thermo switch also ee/ae90 series in the bottom tank. kick in round the 90 deg mark
bigfatmat1,
Jun 9, 5:18am
Quite often toyota switches are n/c not a prob just be aware that you need to wire fan to 87a instead of 87.
falcon15,
May 22, 1:55pm
repco and bnt stock fan switchs. Last silvia i converted to electric fans i just got one of those alloy pipes that normally go into the top hose for a aftermarket temp guage. I just retaped it for a 2 wire thermo switch and put it in the bottom hose and wired it up to the fans via a relay. Repco stock quiet a few differnt thermo switches that turn on and off at different temps so you can work out what works best for you
