Battery isolator switch?
attitudedesignz, Mar 18, 6:32pm
Quick Q for the knowledgable.
Can i put an isolator switch between battery & starter motor!
The reason i ask is the young fella has a Hilux that he's doing up. He is going to have to park in a.umm shall we say 'not a great area' for his work for a week, he can't yet afford an alarm so was thinking the next best thing & a quick temporary solution would be one of those switches.
I have a switch (one of the ones with the red key) out of one of my old race cars and was thinking i could put it between the battery & starter under the bonnet.is this possible.
It's an '88 so doesn't have an electric fuel pump.
I know it won't "stop" a determined thief but it should slow them down enough.
Any ideas!
cheeRS.
bigfatmat1, Mar 18, 6:34pm
yes you can
sgrants, Mar 18, 6:35pm
yep thats a good start! also wire up a flashing led between ign and ground so it flashes when key is off !
bigfatmat1, Mar 18, 6:41pm
thats ign and batt + btw not ground
msigg, Mar 18, 6:42pm
Yes, or you could intercept the wire to the solinoid, or if petrol intercept the 12volt to the coil 9easy to hide a small switch somwhere in the cab. lots of different ways.
jono2912, Mar 18, 6:45pm
If its just for a week - Pull a few fuses.
socram, Mar 19, 6:16am
I do both.
intrade, Aug 2, 7:45pm
diesel you can umplug the silanoid and i wouldremove the battery for the week maybe ;)
wire unplug usually at wiring loom
http://img513.imageshack.us/img513/2713/vepumpyk6.jpg
