Is $760 ok for a cam and water pump replacement?
chrystalclear1, Jun 4, 2:22pm
this included gst aswell.
toyboy3, Jun 4, 2:24pm
if its for the lawnmower ! its over priced
ct9a, Jun 4, 2:25pm
for the 2stroke thats about right
chrystalclear1, Jun 4, 2:28pm
no its for a toyota rav 4
crzyhrse, Jun 4, 2:29pm
If it's a blue car, that's an absolute bargain! But if it's a grey one, you're being swindled!
thejazzpianoma, Jun 4, 2:37pm
chrystalclear, firstly is it a cam replacement or a cambelt replacement. quite different things.
If you are talking the regular maintenance procedure its probably a cambelt replacement, this is also statistically vastly more likely but its important to be sure.
BTW, your name suits you (sorry couldn't help myself)
Speaks volumes.
rta777, Jun 4, 3:07pm
+1
Hope it's not a red one. :)
Seriously - most/all (!) RAVs have "internal" cam-belts (I'm guessing this is what you meant)so that's not too bad a price.Had a old Nissan Pulsar many years ago with an "external" cam-belt - $96.00 to change including all parts and GST.
Nice.
NB: Some vehicles require their cam-belts changed as little as EVERY 60000 kms - check to see if your car does - many people believe all cars are 100000 km intervals - only to have them break doing thousands of dollars worth of damage to their engine.
thunderbolt, Jun 4, 3:10pm
Internal cambelt!
And your pulsar cambelt cost $100 all up because it used a neoprene belt with square tooth profile that was developed in the 1040's for a singer sewing machine, and access was a lot easier than a twin can rav 4.
Cambelt technology has moved on somewhat.
ct9a, Jun 4, 4:00pm
say 5hours labour at $60=$300x1.15=$345inc allowing $415 for parts so must have been a genuine belt,waterpump,antifreeze,cam,-
crank seals,tensioner,idler
chrystalclear1, Jun 4, 4:28pm
sorry im referring to a cam belt
poppajn, Jun 4, 4:30pm
Cost me $860 for cambelt and all other belts on Honda Torneo. 3 hours labour, the rest parts. I was ok with that, cheap insurance for peace of mind
zephyrheaven, Jun 4, 4:35pm
first question I always ask a potential rav4 cambelt booker inner is "ABS!" because that bloody unit in the way makes everything hard
rta777, Jun 4, 8:44pm
True dat! :)
"Internal/external" - sorry, just my way of denoting accessibility.
The $96 was to give relativity - I've seen K series Rovers cost up to $2500 to "change the cam-belt".(Tho' there are also other reasons for such a high cost.)So, in comparison, $760 ain't so bad.
As noted the harder it is to get at the cam-belt means more time = more money.
I would definitely prefer a RAV over that crappy old Pulsar.
Thanks thunderbolt. :)
carmedic, Jun 4, 8:59pm
What!
Where!
When!
How!
ct9a, Jun 5, 8:35am
had to of removed engine and done it on the bench
why! because in the book engine wasnt in vehicle haahaa
danchop, Jun 5, 8:44am
with toyotas id say youd be silly not to use genuine parts,theyre cheap as if your the repairer buying them for cambelt stuff
ct9a, Jun 5, 8:50am
i always use genuine parts unless its a heap
doug207, Jun 5, 9:54am
Easy, buy a cam belt with a rover attached to it. Bloody expensive business mate
poppajn, Jun 5, 4:38pm
Andy, they done cam belt, fan and aircon belt, tensioner and bearings. Tourneo not 5 cylinder Thank god) 5 cylinder is a Ragfa
male_timaru, May 11, 11:50pm
blimey yes - i'll have your bill any day - mine was $1312.00 lol
Cambelt water pump, tensioners, new thermostat, cam cover gaskets and seals and couple of helicoils popped in
