If I'm replacing water pump and belt.
jono2912, Feb 28, 9:33pm
Is there anything else I should be looking at replacing!
1993 Mitsi Magna (2.6)
jono2912, Feb 28, 9:39pm
So. Are they hard to do.! haha - I only dabble with mechanics, Fish.
franc123, Feb 28, 9:54pm
Given where the water pump is on those, no.A new O ring will be supplied with the pump.
jono2912, Mar 1, 10:02pm
I meant the cam/crank seals and rocker cover gasket, Phillip already said pu,p shouldn't be hard.
tshop, Mar 1, 10:09pm
If its a front drive the whole thing he he.
jono2912, Mar 1, 10:11pm
Not mine, but I know what you mean.
msigg, Mar 2, 7:47am
it is one of the easiest water pumps to do, just change the belt and pump.
therafter1, Mar 2, 8:25am
What he said, the water pump is unrelated to anything else, so all that needs replacement is the water pump and its drive belt. The ???O??? ring should come with pump.
jono2912, Jun 6, 3:11am
Cheers for that Phillip. Gonna replace the rocker cover gasket anyway, as it leaks a lil. Cheers
