any one help with some info on the problems i keep hearing about with the 1600 16 valve motors! apparently the factory extractors shrink and cause back pressure and then do the head gasket. any info please
dent,
May 25, 6:34pm
Yup thats correct normally leads to cracked heads and trying to find a second hand head isnt easy. Deffinly worth putting a set of extractors.
rachsb4,
May 26, 6:24pm
is this only limited to the 1600 motor though! the reason im asking is i just purchcused a 2.0l V6 model nomade.
May 26, 6:34pm
No it's not an issue with those, being a V6 its a completely different exhaust setup.
zephyrheaven,
May 26, 6:44pm
V6 = look forward to stretched cam chains! nah just change the oil religiously & they last OK
Apr 4, 10:19pm
.and change antifreeze regularly.you don't want to replace a water pump on those!
