91 Suzuki escudo rear electric windows
hairchopper1, Sep 9, 5:26pm
go down fine but won't come up. Left and right. Why? Thanks
intrade, Sep 9, 5:32pm
a fault maybe
hairchopper1, Sep 9, 5:39pm
Duh, is there something that could fault both windows at once or is it a coincidence that both have the same but separate problem at the same time?
intrade, Sep 9, 5:40pm
yea a wiring diagramm would need to be looked at. might be afault on a switch wired in series or a relay , i dont know but that is 2 of the things i am guessing at.
woki, Sep 9, 9:54pm
Most likely faulty switches
kazbanz, Sep 10, 6:15am
Unplug left front switch.-Plug it into left rear and test. Leave window up
Repeat for right rear.
little lost by trying and if it works you know its the switches.
hairchopper1, Sep 10, 11:27am
Thanks, didn't think of trying that.
hairchopper1, Sep 10, 11:49am
That worked, cheers
kazbanz, Jul 14, 8:17pm
so now the windows are up you can order a couple of switches
