Fuel cost per 40ks on suzuki escudo
john163, Dec 30, 1:19pm
can anyone tell me what there suzuki is running per 40ks im toping mine up every 2 days $50
jmma, Dec 30, 1:25pm
$50 for 80kms, have I got that right or do you have a big problem (o:
smac, Dec 30, 1:33pm
Just guessing.but I think they mean 2 days both ways so 4X40kms.who knows.still really high.
theram1, Dec 30, 1:39pm
might have meant 400 km.
john163, Dec 30, 1:40pm
40ks its a round trip
jmma, Dec 30, 1:46pm
Then its pissing out somewhere (o:
splinter67, Dec 30, 1:48pm
$50 for 40ks hell my big block is looking good
brokebloke1, Dec 30, 1:51pm
sounds to me hes getting 80kms for $50 !
if so my Falcon is bloody great I get 200kms for $50 around town, better out on the open road,
john163, Dec 30, 1:56pm
so is my twin tunnel ramed small block, its $50 for 80ks for the suzuki its been creeping up ive been toping it up when needed never worried about it untill I looked at the bank acount
splinter67, Dec 30, 1:59pm
Yup that aint right does it run ok check your air filter
Yup that aint right does it run ok check your air filter is it dragging a brake
john163, Dec 30, 2:05pm
done that, full service, oil filters etc etc had the scan tool on it with no faults checked under the car & fuel lines no leaks it does go gutless sometimes on roundabouts all I have to do is give the throtal a kick & it takes off again
brokebloke1, Dec 30, 2:05pm
Is the suzuki a 1600 auto! if so my daughter was just saying it cost her about $40/100kmswith the overdrive turned on.
john163, Dec 30, 2:11pm
yep 1600 auto so something is wrong with mine hmmmm if it was a horse it would have been put down buy now
brokebloke1, Dec 30, 2:16pm
make sure that you havnt put it into 4wd as this will suck the gas on these things, also have you changed plugs/air filter and what conditon is the catalylc converter like! we removed the one from my daughters and just have a straight pipe as the converter had collasped inside and was making the car use more gas.
john163, Dec 30, 2:18pm
removed converter changed plugs etc its not in 4x4
brokebloke1, Dec 30, 2:22pm
cleaned fuel filter and pump!
jmma, Dec 30, 2:48pm
Someone sucking it out at night (o:
msigg, Dec 30, 4:37pm
Well something is wrong if it dies and you gott to kick the accelerator down to make it go, go and get someone to give it a tune up. spent $200 then you might save it back.
splinter67, Dec 30, 4:48pm
Did you do the service or was it done at a garage if not you check the air filter a lot think a full service is an oilchange and a filter. Is it carbed or injected if injected get some injector cleaner
morrisman1, Dec 30, 4:51pm
has the oxygen sensor failed!
Pull out the plugs, if they look nice and tan colour then chances are it is not engine related. If they are all black and sooty then definetely an engine management issue.
neville48, Dec 30, 6:51pm
get rid of the cat converter and clean yur injectors and clean the throttle body.
john163, Dec 30, 8:11pm
I did the service my self changed oil fuel air filters changed plugs leads oil etc still bogs on right hand corner (roundabout) put scanner on no faults
llortmt, Dec 30, 8:14pm
OK so when looking at live data what happens when faulting!
splinter67, Dec 30, 8:15pm
not sure but stay away from roundabouts and you'll be fine lol
sorry couldn't resist that
