Can someone help ?1275 a series engine manifold
steinway2, May 21, 6:20pm
is the 1275 a series engine manifold the same as the morris marina 1300 engine manifold to take the stromberg carby! cheers
digger80, May 21, 7:12pm
a 1275 had an "SU" twin 1 1/4" carb set up,that is the '60's cooper 'S' model,later models with that size motor-called 1300's- had just one 1 1/2 carb'BMC didn't use stromberg carbs on'A' series motors
steinway2, Mar 17, 4:58am
thaks for that digger80.so are the 2 carbys interchangable then!
