Petrol smell
dinky65, May 15, 6:39pm
got a petrol smell in my mk3 zephyr when driveingwindows up cant smell window down can .dun boot rubber bent tail pipe checked fuel lines
jason18, May 15, 6:43pm
Carby leaking some where!
johnf_456, May 15, 6:43pm
Well check again it has to be leaking from somewhere
bluecambridge, May 15, 6:45pm
don't light a match
karlandkell, May 15, 6:50pm
Check the gaskets at the top of petrol tank where fuel guage fitting is.
m16d, May 15, 6:53pm
Ha. Mk3 fizzer. Had a few of them in my time.
Can't help with the fuel leak but. shouldn't be too hard to find.
Hmmm, its not a leak in the top of the tank letting fumes into the boot is it.!
mugenb20b, May 15, 7:11pm
Fixed.
smilie13, May 15, 7:16pm
check gas lines, from the front end of car to the back to the petrol tank. Good luck
johnf_456, May 15, 7:19pm
Check it on a hoist if you can
sr2, May 15, 8:09pm
With a mechanical fuel pump the fuel line is under a small vacuum (i.e. being ???sucked through??? as opposed to being under pressure) and probably not the culprit you are looking for.I??
biddy6, May 16, 6:36am
Rust on the top of the tank, can be hard to spot.
dinky65, May 16, 4:48pm
thanks for those options ill work through them
saki, Feb 25, 5:49pm
air is being dragged in throug boot/tail light caused by the air being sucked out through the window you have a low pressure in the cabin.try openg the vents to repressureize the cabin
