i have been asked if i knew where i maybe be able to find morris marina 1300 running gear an motor so i thought id ask around . can any one help! thanks
jasongroves,
May 6, 7:16pm
Out of one of these! 1964-1971 Austin/Morris Mini Cooper S, 76 hp (57 kW) at 5800 rpm and 79 lb·ft (107 N·m) at 3000 rpm 1966-1970 Austin-Healey Sprite MkIV, 65 hp (48 kW) at 6000 rpm and 72 lb·ft (98 N·m) at 3000 rpm 1966-1974 MG Midget MkIII, 65 hp (48 kW) at 6000 rpm and 72 lb·ft (98 N·m) at 3000 rpm 1967-1968 MG 1300/Wolseley 1300, 58 hp (43 kW) at 5250 rpm and 69 lb·ft (94 N·m) at 3000 rpm 1967-1968 Riley Kestrel 1300, 58 hp (43 kW) at 5250 rpm and 69 lb·ft (94 N·m) at 3000 rpm 1967-1968 Vanden Plas Princess 1300, 58 hp (43 kW) at 5250 rpm and 69 lb·ft (94 N·m) at 3000 rpm 1967-1973 Morris 1300, 58 hp (43 kW) at 5250 rpm and 69 lb·ft (94 N·m) at 3000 rpm 1967-1974 Austin 1300, 58 hp (43 kW) at 5250 rpm and 69 lb·ft (94 N·m) at 3000 rpm 1967 MG 1275/Riley 1275, 58 hp (43 kW) at 5250 rpm and 69 lb·ft (94 N·m) at 3500 rpm 1967 Wolseley 1275, 58 hp (43 kW) at 5250 rpm and 69 lb·ft (94 N·m) at 3500 rpm 1967 Vanden Plas Princess 1275, 58 hp (43 kW) at 5250 rpm and 69 lb·ft (94 N·m) at 3500 rpm 1968-1969 Riley Kestrel 1300/Riley 1300, 70 hp (52 kW) at 6000 rpm and 77 lb·ft (104 N·m) at 3000 rpm 1968-1971 Austin America (automatic), 60 hp (45 kW) at 5250 rpm and 69 lb·ft (94 N·m) at 2500 rpm 1968-1973 Wolseley 1300 (manual), 65 hp (48 kW) at 5750 rpm and 71 lb·ft (96 N·m) at 3000 rpm 1968-1973 MG 1300 MkII, 70 hp (52 kW) at 6000 rpm and 77 lb·ft (104 N·m) at 3000 rpm 1968-1974 Vanden Plas Princess 1300 (manual), 65 hp (48 kW) at 5750 rpm and 71 lb·ft (96 N·m) at 3000 rpm 1968 MG 1300/Riley Kestrel 1300, 65 hp (48 kW) at 5750 rpm and 71 lb·ft (96 N·m) at 3000 rpm 1969-1971 Morris 1300GT, 70 hp (52 kW) at 6000 rpm and 74 lb·ft (100 N·m) at 3250 rpm 1971-1982 Mini Moke Californian Australian only. 1969-1974 Mini 1275GT, 59 hp (44 kW) at 5300 rpm and 65 lb·ft (88 N·m) at 2550 rpm 1969-1974 Austin 1300GT, 70 hp (52 kW) at 6000 rpm and 74 lb·ft (100 N·m) at 3250 rpm 1971-1980 Morris Marina, 60 hp (45 kW) at 5250 rpm and 69 lb·ft (94 N·m) at 2500 rpm 1971 Austin Sprite, 65 hp (48 kW) at 6000 rpm and 72 lb·ft (98 N·m) at 3000 rpm 1973-1980 Austin Allegro, 59 hp (44 kW) at 5300 rpm and 69 lb·ft (94 N·m) at 3000 rpm 1974-1980 Mini 1275GT, 54 hp (40 kW) at 5300 rpm and 65 lb·ft (88 N·m) at 2550 rpm
morrisman1,
May 6, 7:21pm
nah jason, that ugly beast is FWD. The marina (ugly too) is RWD
(referring to your first link)
jasongroves,
May 6, 7:23pm
Ahh.so it is.ooops.
morrisman1,
May 6, 7:24pm
dont worry, I got corrected for the very same mistake about a week ago.
jasongroves,
May 6, 7:25pm
Just put a 4AGE and T50 gearbox in it and be done with it;)
ginga4lyfe,
May 6, 7:27pm
a morris minor running gear would be similar, but not great, It would be better for you to find a Datsun a12 engine and running gear very similar and heaps easyer to convert to injection
May as well use an A15 if you going to go that route.
mgmad,
May 6, 7:34pm
RWD 1275 A series engines are getting hard to find, and as such have been commanding quite high prices up around the $1k mark. Gearboxes less expensive but still hard to find as a lot tend to throw them away (they are a bit crap). It is possible to get recon boxes ex UK though. Diffs come up for sale from time to time, try on here or car clubs, all the bits to recon them are still available new including new CW&P sets, but they're not cheap.
ginga4lyfe,
May 6, 7:41pm
I was thinking about mentioning the A15 But wasnt too sure whether or not the engine was all that great!
robinm1,
May 6, 7:46pm
I had one of those beasts years ago, I repowered it with aHolden starfire motor and box out of a UC Sunbird. Was an easy transplant and went well.
jasongroves,
May 6, 7:58pm
No offence.but a Starfire! Eewww!
robinm1,
May 6, 8:07pm
It was a long time ago, the starfire was a modern near new motor at the time.
May 6, 8:10pm
Yechhh, wouldn't that have netted a car with no more performance but worse economy lol!Those thing were regarded as bottom of the pile even when new.
robinm1,
May 7, 7:20am
Sorry, mind was a bit hazy after all the years past since the conversion, it was not the starfire, it was the 1900 opel motor from the LH torana now I think about it.
mrfxit,
May 7, 7:38am
EEWWWW holy crap . NOOOooooo not a 1900 Opel . surly NOT Good grief those ARE the bottom of the biggest pile of crap motors EVER put in to a Holden.
The 1900 Star fire motor was in fact a fairly good motor in it's day, altho mostly because it was basicly a cut down red holden 6cyl 173ci. A lot of the parts could still be interchanged between the 4cyl & any of the 6cyl versions (black or red)
mrfxit,
May 7, 7:40am
Hell no, the Holden Star fire had better performance all round (except for the jap stuff)
elect70,
May 7, 11:58am
been toldbox same as triumph toledo.
May 7, 4:14pm
Than what, a ride on mower!The lack of peformance and economy from the Starfire was appalling.Worse than that of a 2L-T powered Surf in fact which is saying something :)0-100km/h in 19 seconds anybody!In fact ditch the stopwatch and use an egg timer instead.
elect70,
May 8, 10:36am
I remember that star fire thing in early commies, huge POSwouldnt pull the skin off a rice pudding
mrfxit,
May 8, 10:57am
LOL . Still pretty sure you're all confused between the Opel (large black tin tappet cover) & the cut down holden 6 with a narrow blue tappet cover.
The Opel was the most gutless 1900cc engine I had ever driven
I have had this engine for over 20 years in my garage, is it a Morris engine12V/587Z/L14536 ?
